• In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
  • Most users ever online was 129 on Wed May 13, 2020 12:34 pm
  • Users browsing this forum: No registered users and 1 guest
It is currently Fri Apr 19, 2024 7:10 am
Change font size
Tech Talk
Wiring a 24 Valve VP44 Cummins
Post your technical threads here
Postby jeremylawson » Wed Mar 13, 2013 1:33 pm
Here is the basic wiring diagram for the 24 Valve Cummins.
To make it run you should only have to do this :
On the ECM you have a red/white wire at pins 48 and 50 they need 12v.
On the injection pump pin 7 red/ltgreen 12v.
Grounds are pin 6 (injection pump) and pins 30 and 49 on ECM, all are black/tan.
Then big wire to starter and neg to block and then jump the starter. The wait to start light is pin 37. That should be keyed power through the bulb and then the computer will ground it to turn it on.
Resistance is Futile.
User avatar
jeremylawson
Site Admin
Return to Tech Talk
cron
User Menu
Login
Login
